oddd1
richieb
oddd1 i would like to pick your brain for a minute if i could.<br /><br />------------------
ODDD1
Re: oddd1
about yer no start on the 3.0? if it cranks over but no spark..first check points/perhaps bad condensor....umbilical harness plug always a problem...is a molded wire plug about inch an a half in diameter..pull it an check for corrosion, make sure it has a hose clamp to hold it together...ther is no overheat disable, they will run till they lock up...150 normal....careful on the water pump change, savin money a wonnerful thing, but this procedure has plenty of room for disaster,specially for a rookie...
