odd cooling issue
petersbc
Not really an issue any longer i think but here is what happened. 79 Johnson 140
Just rebuilt the power-head, bored out, new pistons bearings the whole thing. Put it back together and was test running it and it overheated, alarm went off. The WP telltale seemed a bit weak but it's new water pump and the hump was fairly cool so i thought it was ok. Pulled the elbows off the T-stat housing and they were dry. Started the motor an no water from the head but did not run it for more than a few seconds. After letting it cool off and checking the WP to ensure it had not come apart, it's new but still, I started the motor with the elbows off and after several seconds of running got gushing water from the heads. Put it all back together and ran it for about 15 minutes at varying speeds and all was well. Heads were running 147 with an IR thermometer.
Was this an air bubble trapped in the motor? Should i be concerned? Need to get it out to the lake but do not want to have problems especially on a fresh motor.
F_R
Honorary Supreme Mariner
I would doubt the air bubble theory.
+++++ With the above.---Every time an outboard starts the block is full of air.-----Did you replace the water deflectors ??
Fed
Were you testing in a tub, maybe the water level was too low?
Needs to be a few inches above the actual pump which is much higher than the intake vents.
petersbc
Was testing with the muffs plenty of water flow. I did not replace the water deflectors but they are in place and in good condition. It seems to be running fine now. Yes the air bubble thought does not see logical but it all cleared up running it with the elbows disconnected.
Really odd.
clemsonfor
I'd vote for putting that thing in water. Actually submerging the foot to proper depth in water. I just chased my intermittent issue for days each time I have 15 mins or so to work on it. Dropped the foot after it was togeather, rechecked the water pump. All for a wacky stream out of the teltale. Problem just running on muffs. I have 2 other motors on bigger and smaller than this one, neither has the issue. Learned to submerge the motor or wacky thing may happen.
petersbc
That is the plan in the am. We shall see. Reupped my towing insurance so...... ;)
