"O"ring ?
SS MAYFLOAT
It appears that the Orings that I need for my fuel rail is a dealer item. The orings are not cracked and are still flexible, but they are flattened where they seal at.<br /><br />Was told soaking them in brake fluid could get them to swell a little, but make sure the excess is cleaned off before installing. Guess it wouldn't hurt to try it.
tommays
Re: "O"ring ?
i would not due it unless i was going to have to walk !! i replace a lot of leakey o-rings<br /><br />tommays
Re: "O"ring ?
Ayuh,......... It's hard to Admit,..... I buy those at the Stealership.............<br /><br />Sorta right up there with the Marine Electrics on a boat,........<br /><br />Stray Gas Is a likely,........ Boom.............. :(
ndemge
Re: "O"ring ?
My .02:<br /><br />If the o-rings were are the sole problem you are fixing, then just bend over and go buy them.<br /><br />If you were replacing something ELSE that was wrong, and they were not leaking before, and you just notice they may need replacing, AND, if it is a very easy thing to get at, it might be worth a shot re-using. But if it takes an hour to tear down just to get to the lil buggers, i'd replace with new.<br /><br />.....and if you have time to wait, watch the ole ebay for a month, never know who might have a set to put on.
SS MAYFLOAT
Re: "O"ring ?
Its not that big of a deal to get to the fuel rails, at least not now after getting to them several times. :( <br /><br />The car has sit in the garage since I redone the heads. I had everything back together and then found out the timing belt tensioner was bad. Didn't have the extra cash to get the part. Finally the weather broke a bit and did a side job to get the cash for the tensioner. <br /><br />Yep Noel, they started leaking because of being moved around while doing the heads. They were not the primary problem. Now it is! It is just unbelieveable that those particular rings are a dealer item. The parts stores have the oring kit for the injectors. The orings I need are the ones that hook the gas line up to the fuel rail that the injectors sit in.<br /><br />When the partsperson asks me my name, I'm gonna say "My name is Ben Dover". :eek: <br /><br />Thanks,,,,,,,guess I gotta do what I gotta do and get over it! :)
dolluper
Re: "O"ring ?
Never ,never re-use those o-rings,always install BRAND NEW ONES,I lube them with trannie oil {automatic] before I install them.For the sake of maybe 5 bucks come on EH!!!!!!!
SS MAYFLOAT
Re: "O"ring ?
Yep, no need to worry, I will get new ones. I just wouldn't feel right if someone got hurt because of a minor part that does a major job.<br /><br />I maybe using the engine/transaxle to put into the car in the pic. It will give me better A/C, heat, rear disc brakes, and some excellent power to weight ratio. Any ideas of what this car is?<br />
<br /><br />thanks for the concern, IT IS appreaciated! :D
Reel Poor
Re: "O"ring ?
Originally posted by SS Mayfloat:<br /> Yep, no need to worry, I will get new ones. I just wouldn't feel right if someone got hurt because of a minor part that does a major job.<br /><br />I maybe using the engine/transaxle to put into the car in the pic. It will give me better A/C, heat, rear disc brakes, and some excellent power to weight ratio. Any ideas of what this car is?<br />
Porshe???<br />Opel GT???<br />Really doesnt look like either, Buuuuttt, just guessing
SS MAYFLOAT
Re: "O"ring ?
Pointer, now have you ever seen a Bradley with a hard top? and doors? and headlights like this one? now are you sure of your answer? :confused:
dolluper
Re: "O"ring ?
Fiat or Opel is my guess,have seen them in the 70's what does the back look like
Re: "O"ring ?
Looks alittle like an old Advanti(sp).......<br /><br />I remember 1 from Years ago a friend had, back in Maine,......<br />His was Older,+ Rounder in it's Styling.......<br /><br />A Nice little British Sports Car......<br /><br />Or was the Advanti the name of the Studebagger Sports Car,..???<br /><br />Man,..... Loosing your Memory $uck$,.......<br />I can SEE the Car,.... Just Can't remember the Name on it.........
Re: "O"ring ?
No,......... Wait,......... I Got It,......<br /><br />How about a Saab Sonet,..???....
SS MAYFLOAT
Re: "O"ring ?
Believe it or not, it is a Bradley GT. My Dad got into an argument with the kit car company. They wouldn't sell him any parts even though he had his own body shop business. So he said he was going to fix it so it wouldn't look anything like a bradley.<br /><br />Headlight pans are off a 67 beetle<br />Roof is from a VW squareback<br />Rear hatch is from a Datsun B210<br />Doors also come from the squareback<br />Tailights are from a 72 Toyota <br />Windshield is still the stock one which is from a 67 vette.<br /><br />The car got handed down to me when my parents passed away. Fun to drive, just those drum brakes suck. It has the porsch 914 2 liter in it now. The heater still aint worth a crap.
dolluper
Re: "O"ring ?
Funny I was thinking the front looked a bit like a Datsun 240Z,after you fix her put some Ford decals on it throw everybody for a loop
