I would like to know how many "poles" are on a Johnson 150 so I can set my tach up to work.The numbers on the back of the tach on the dial are as follows:<br /> # Poles set<br /> 4-1<br /> 6-2<br /> 8-3<br /> 10-4<br /> 12-5<br /> 20-6<br /> I had to replace the solenoid so I pulled all the wires off and replaced it and reconnected the wires to the new solenoid after which I tried to see why the tach wasn't working.It wasn't working, I thought, because it was set to # 6, I switched it to the number 4 and it started working. Well today while changing out the fuel line I found a wire that I had forgot to reconnect to the solenoid, it ran up to a little pack on the top of the engine. So after I reconnected that wire and started it the tach no longer worked. I have power to the because when I turn the key it goes to Zero just nothing after that. I've also turned the dial on the back of the tach to every number and still nothing.
