msaunoras
- May 30, 2012
- 46
The carb on my 05 Nissan has never been apart or cleaned. I run it dry in the winter, dump fresh fuel with Marine Stabil in it in the spring and run it all season long (with new plugs of course). It's never given me any reason to think it urgently needs cleaned. It does run a little rough at idle but it has never stalled and doesn't give me much trouble starting up (I don't know what RPM it's idling at yet but I intend on getting a tach). It stands to reason it could use a good cleaning but outboards are not my expertise. I did pick up a factory Tohatsu service manual and Chapter 7 gives a little hint of what to look for but other than that I don't know what to expect. Is it as simple as disassembly, soak and reassembly? Are there any adjustments that need to be made other than the throttle stop and throttle linkage?
I see individual carb parts appear to be available and not very costly, would I be better off replacing parts like the main nozzle, main/slow jets, float valve and accelerator pump parts? Any other gaskets or rubber parts I should be on the lookout for?
