Had to replace the impeller. there ws nothing left of the old one. It seems you have to cup the impeller blades to get it to fit in the housing. My question is do you have to have them cupped a certain way to get flow or will the revolution of the motor turn the blades the right way once it starts.
I had a hard time getting it back together and there is no water flowing from the pee hole. Is it possible to install the lower unit without getting the tube that sends water back up to the motor in the pump housing?
As I said no water coming from the pee hole just coming out of the lower unit.
Any help would be appreciated.
