Ns70a2 360-1
handyfella
Hello Tohatsu Nissan gurus
I downloaded a fsm for a newly acquired ns70a2 360-1 runs great but but sputters a little at low and part throttle under load so I want to go through all the settings and get it back up to snuff
I have built carb sync tools in the past for old motorcycles and got them running perfect but I don't see vacuum ports on these carbs anywhere
The fsm I downloaded is really vague about setting the timing and I don't even see a timing mark on the flywheel lol
Hopefully someone has better detailed info than I have found for setting up the carbs
I got the link between the carbs to exactly 110mm, and I noticed the idle screw and pilot screws were all set to 2.5 turns so I corrected them and plan to set them next time we're at the lake
Thanks for any guidance
Matt
handyfella
Just using factory settings on the pilot and idle screw it idled a touch high but seems to be good settings for the pilots
I still really wish I could figure out how to sync the carbs
pvanv
If they both close completely at idle, you should be good.
