nothing works
twister315
turn key nothing happens ,nothing works batterys brand new 2016 evinrude 250 on a 2016 key west everything worked fine earlier in day stopped to fish ,then tried to start nothing happened please help thanks
tphoyt
Look for an in-line fuse from the + battery terminal. Do you have a battery selector switch? If so check that to see if it’s still working or not.
oldboat1
^^agree. Find and check fuse (simple continuity check unless obviously blown) as a first step.
twister315
got everything working again, except motor when i turn key to start, everything goes back out could the circuit breaker be bad everything comes back on when i turn selector off then back on
