nothing over 1000 rpm's
Bcultice
I have a 1996 mercury 150 blackmax XRI EFI that ran great, till it all of the sudden wouldn't get over 1000 rpm's I can give it gas and it's like it's just bogging down, I have replaced the water separator filter, the plugs, and primer bulb and half of the feul line, when it started this it would do it for about an hour then run fine for a while then do it again, now it just does it all the time, any help would be greatly appreciated
boobie
Go over your fuel system again and then do a cylinder drop test on it when it's acting up.
Bcultice
when the engine is doing its running bad thing I can smell gas pretty strong, plus after it has been running and I pull the plugs they are still wet
wired247
Probably dropping a bank of cylinders It doesnt take much power to rev up with no load if 3 cylinders are working
Chris1956
Gee, that motor has a high speed and low speed stator windings. Does it have spark on all 6, when you try to accelerate?
