Re: Not pumping oil to reserve tank
you should read up on how the system works. the main tank is on the engine, the sub-oil tank also known as the remote tank is mounted outside the engine on the v4 v6 yamaha's. not knowing what year yours is nor what HP it can be several diffent things. some wont transfer if the engine is trimmed or the trim sender is bad, others wont transfer if the engine is not running. if the yellow lamp is lit no oil will transfer . the manual switch just supplys a path to ground for the remote oil tank pump. if you have 12V key on, and hit the manual switch it will transfer. if it wont start hunting for a break in the blue or the tan wire between the motor and the tank. search for a bass and walleye article on this forum for precision blend.
