Hi there,<br /><br />seems not to be my day for a compression check.<br />Got a problem on Sunday, engine (1990 90 HP OMC)<br />lost power partly and died on idle, hard to start.<br /><br />Tried to check compression today, pulled spark plugs, checked the first 3 cyls. While unscrewing the gauge from cyl 3, I realized that the adapter ring was still in the threading, partway in and now didnt came back out. <br />(The previous owner had damaged the threading and had a slightly wider one drilled in the head with an "adapter" ring to fit the normal spark plug)<br /><br />Any idea how I can get this ring out without pulling the head ???? <br /><br />Thanks
