Not much water from the pee hole...
bonehunts
I have a 1990 85hp Yamaha and I have replaced the water pump and housing. There's a small flow of water coming out of the top hole but there's a rush coming out of the lower unit itself which leads me to believe there's either a seal not right where the tube goes into the housing or the tube's clogged. Sometimes it stops all together which makes me think there's a possible clog but I really don't know.<br />First, any suggestions on what to look at to see why there's not much flow? Secondly, is there an easy way to get to the top of the tube to make sure it's cleaned out all the way?<br />Chris
rodbolt
Re: Not much water from the pee hole...
hello<br /> remove the tell tale hose from the block and blow into it with the red tube and a can of carb cleaner. check the pressure relief valve and tstat assy.<br /> should have a good stream on that motor.<br /> good luck and keep posting
bonehunts
Should it have water coming out as soon as it starts or does the tstat need to warm for a while? Where's the relief valve?
bonehunts
I'm also curious if the water tube should just come out when I replace the water pump. Mine's stuck up in the motor and didn't know if it just pulled out or what it took to get it out.
bonehunts
Well I just went out and blew air into the hole where the tell tale hose hooks to the manifold and eneded up getting a good stream. I wonder if there's somethign floating around in there that would be causing tha back up...
rodbolt
hello<br /> nope water tube stays in the exhaust housing. leave it there<br /> the pressure valve is located under the t-stat cover. <br /> sounds like ya have some scale or sand in there. does not take much<br /> we fight it all the time here<br /> good luck and keep posting
