Sheltering
- Oct 31, 2012
- 25
I have been on this forum a few weeks ago with a similar problem. I have a 1993 Johnson 65 hp that I had a very hard time getting to idle and run properly. So far all three carbs have been removed & cleaned, and subsequently, after discovering one carb was spitting out gas while idlying, I changed all three float needle valves and seats. I also ran a can of seafoam through a tank of gas. I also removed and cleaned the fuel pump which seemed to be in very good condition.
I still cannot get motor to idle consistently. Sometimes it will race while other times it will die when I place it in gear. I had it out yesterday and at first it ran good and then even at full throttle, it would only run a bit better than idle with which I limped back to port. I believe this problem was caused by the fuel primer solenoid being in an improper position, as it started right up later when I changed the direction of the red button on the solenoid.
I tried in the water again today and was encouraged that it seemed to work very well at high speed, but when I shut it down, it was still very hard to start and keep idlying.
I believe I am out of options and would appreciate any help anyone can offer. I am reluctant to travel any distance from the shore as it is so unrealible.
Don in New Brunswick
