Re: not enough RPM's!
"I tried both the trim and the tabs and they have a lot of effect. I usually start with the tabs up and the trim down. Then when the boat picks up speed, I raise the trim until the boat starts bouncing, and then go a little back down again. I usually only use the trim-tabs for balancing the boat once planing." <br /><br />I'm know nothing about mik's motor or about the size of his large boat, i'm used to small boats. but i got a question about what his rpms are, trim down, and then trim up. all boats i've delt with ya start out, trim down, after plane, ya trim it up. rpms increase, at the same throttle position. at wot, the rpm's increase to a point where you got the drive so high it starts to ventalate, no load. what happens when ya get to this point mik. 4200 rpms? as for the tabs, perhaps i don't understand them either, have no expereince with tabs. but i thought ya started out with the tabs down, thus getting plane faster with less bow rise. after plane i though ya brought them up to a neutral position, thought this added planeing surface and perhaps speed increase. tabs up??? why. ya say that ya use the tabs for balanceing the boat, why do you need to do that too? is your load offcenter?? maybe the trim has nothing to do with your problem mik. all i do know is that the boat i got i can keep the rpms down, just by trimmng full down, about 4000 wot, trim it up and i can get 4500, much above that and i start to ventalate and get unhooked and overrev. what happens when you over trim up mik. still only 4200? if so i'd think back to the motor problems discussed above. just my 2cents, jim
