Here is my problem and I hope you guys can help. I have a 1987 johnson 150HP outboard that got a new powerhead in 1995. I had the carbs rebuilt in May of this year because I bought the boat used in Jan and it had been sitting for over a year. When I start the engine it starts up fine using the fast idle lever but when I push it down the warning alarm goes off in about 15 seconds and will not go off until I put it in gear and give it some gas, after that I get the alarm sporadically, sometime it goes off by itself and sometime I have to squeeze the ball. I first thought it was a false alarm so I continued to run it when I have it wide open and trimmed up but sure enough the ball flattens out and I have to stop and then squeeze the ball. So far I have check all of the fuel lines from the hose inside the gas tank to the connector on the engine plus the air vent and all are clear and I have changed the ball. It seems to me that the engine is doing what it is supposed to but it can't gas fast enough. Any ideas on what I should check next ? The carbs and fuel line is the limit of my novice outboard knowledge and any help would be much appreciated.
