Ok, I dont think it matters that its an evinrude in this case, but anyhow, my boat has been sitting for about 3 months now, and I made the repairs it has been needing. I have had a problem with the steering arm/cable getting sticky when it sits for a while, so i lubed up the arm, and slowly started working the wheel back and forth to work in the grease. I have had this problem before, but it never stays stuck. A little heat and added lube combined with some jiggling, wheel turning and hammer tapping usually frees her up. However, this is not the case this time. It always seems as tho the trouble lies with turning the wheel counter clockwise, as to make a left turn, which causes the arm to go "in". I turned the wheel all the way to the right, exposing as much of the arm as possible, slathered it up with grease and inched it back and forth, further each time, untill it got stuck. I finally fixed the problems that were previously keeping me off the water, now this silly predicament is keeping me dry. It seems like it never ends!!!!:'( I have tried everthing that usually works, any suggestions?? I even heated it more than usual, and introduced grease via the grease gun recievers for this situation. I also tried turning it by grabbing the engine itself, standing outside the boat and trying to jolt it free. HELPPP!!!!!
"stuck",
mrbadfish:|
"stuck",
mrbadfish:|
