Re: Non working power trim & tilt stuck in down position
hello, I'm on a roll, i hope, determined that one on the relays was bad, found it rusted completly under the cover. i was able to run the trim up/down as suggested but it was tricky because the ground in normal thru the relay and switched to positive by the oparated relay. the probe showed the ground from the motor winding, and rust was too much resistance to run the motor. <br /> the relay that came out of the unit was a hella, 260388-10, obsolete number. had to go to hella, they cross refereced to he-87423, and sent me to a dealer. relay not available, substitute a<br />he- 87499, the difference is a resistor accross the contacts. ? not sure what that does forme, but order 3 of them, 5.96,+ 3. p/h.
