I just got a used boat with a volvo 3.0 engine and an SX-M outdrive. The boat is a 2001 model. I test ran it on a lake before I bought it and everything seemed nice and quiet. It was always run in fresh water (according to the seller).
The drive has non-volvo gear oil in it (it is kind of black, but not because it is old). I want to switch back to the "correct" volvo gear oil. I was planning on draining it as much as possible, filling with volvo oil, running it for a short time, then drain and refill with volvo oil. Is this a good idea?
When I take the drive off, I'll check the alignment with an alignment bar. Will I be able to tell if the universal joint is OK? Anything I should look for other than the obvious water in the bellows?
Also, what grease should I use for the gimbal bearing (the grease fitting on the side)? It would be really helpful if someone could list out all of the grease and adhesives (something about putting sealant on the threads when installing the drive?) that are needed for the bellows replacement.
I am planning on replacing the bellows even though they look OK, and have ordered all of the service manuals and parts. I am also replacing the impeller since it is probably the original. I don't think that there are many hours on the engine (no hour meter).
Finally, does anyone have the part number for the plastic covers that go on the ends of the trim "posts" (big stainless steel bars where the trim cylinders attach?) Are these just cosmetic?
Thanks,
Fred
Thanks,
Fred
