Non alpha drive on a alpha one gimbal housing
CatriderF7
I bought a boat for parts (1985 starcraft) that had an alpha one engine/transom assembly. The guy said he had an issue with the outdrive at some point and replaced the upper/lower gear gases with an older non alpha style. I was always under the impression this couldnt be done. The reason he sold it was because it wouldnt circulate water through the engine, even on the hose attachment water wasnt getting to the engine. I assumed it had a bad water pump or plugged hose somewhere. I already pulled the engine/drive and scrapped the boat but was just thinking maybe this combination of the drive just didnt work together and that was the reason for the issue he had?
smokeonthewater
Depends on what you are calling non alpha... R/MR/ALPHA are all interchangeable.
Look to see if the water hose next to the bellows is kinked.
alldodge
Got any pics or part umbers your working with?
Bondo would be able to answer all your questions with the older drives
CatriderF7
Heres a couple pics. I dont have any part numbers though
alldodge
This is a MC-1
fetch
Alpha one
fetch
I don't think they fit correctly,
Ayuh,.... The MC-1s will bolt onto the Alpha 1 gimbel housin', 'n run just fine,....
The MC-1s are a direct swap with the Alpha 1s, but not the Gen.IIs,....
The Gotcha's involved are the old MC-1s for GM in-line motors have a shorter input shaft, that must be replaced with the longer shaft,...
'n the older MC-1s have different spline counts 'tween the upper, 'n lowers,...
So, swappin' entire drives are Ok, 'n easy, so long as the longer input shaft is used,...
'n uppers, 'n lowers can be swapped so long as the spline counts are the same,....
