hanoverboy
- May 22, 2010
- 1
I just bought a 1995 Four Winns with a Volvo Penta SX Cobra outdrive, 5.0 Ford. The boat is in excellent shape and has 300 hrs. on it. It runs great but at idle in neutral it has an annoying noise. When you engage it in gear all is quiet and works well. At first I thought it was the u-joints so I pulled the outdrive and checked them, the gimbal bearing and the gimbal to coupling alignment - all was fine. With the outdrive removed and water supplied to the motor there is no noise when running - I even removed the splined shaft from the u-joint and placed it into the gimbal and coupling - and still no noise. I now suspect the problem is in the upper gearcase, possibly the cone clutch, gears, shaft or bearings. Is this a common problem with this unit and is there an easy way (besides tearing down the drive) to determine what might be the problem?
