Re: Noise suppression headphones(shooters)
I would agree with peterf.<br />We recently started using the Peltor brand at work (I work on a flightline as a mechanic, around running jet engines) and we still double up when within 50 feet of a running engine or Auxiliary Power Unit (APU). They work great in all other situations. I have been working out here for 19 years, I didn't always wear the protection when I was younger. I have lost about 20% of my hearing and will never get it back. The Peltors have solved the reason I wouldn't wear them back then, well that and age. You can hear the radio, people talking, all that stuff. There is a volume control, that makes it really sensitive. However, sharp noises and high db noises are cutoff. The reason we double up around the running engines and APU's is that it is a constant noise. The Peltor's will cut off the volume on sudden noises or changes in level. It doesn't seem to do that with more constant levels. It also only reduces a certain amount of db and the engines, especially at max power are WAY above that.<br /><br />AK Chappy
