Re: Noise from carbs when pumping primer bulb. 86 120 ER
Hey boobie, umm hard to say, it will idle for a bit then want to sneeze and die, I also have a dead spot at about 1500 rpm, if you try to throttle up slowly it will start to die, which is when you have to nut it wide open to keep it going. The same goes for throttling down to that 1500 rpm range, it will start to die then I have put it in neutral and hit the fast idle. pain in the ***.
Once she's at full speed though it runs great, and will putz around nicely at about 2800 -3000 rpm. Just that damn 1500 rpm range.
Cheers
