randyd9546
- Jun 20, 2003
- 8
I have a 1987 yamaha 25sh which is a 2 cylinder single carb,it runs fine most of the time but sometimes when you take off it will only get about half throttle and just boggs,you can let off and let it idle or kill it just for a few seconds and take off and it is usually fine again.I have replaced plugs 3 times changed fuel tanks,rebuilt carbs twice the second time added a in line fuel filter and pumped line to clean before installing hose,added new fuel tank,fuel line with new bulb,no help,grounds are good on coil no leaks,does not help to pump bulb or choke,i found it didn't have a thermostat so i installed one and decarbed with merc spray but it has been raining so i can't see if that helped.I just bought motor this fall PLEASE HELP.
