i bought a 1987 25 hp Nissan and went ahead and replaced the impeller.the old one looked fine but i have no stream.does anyone know what i did wrong? or what might be the problem.
Assuming you got the impeller key in the slot on the shaft and the correct impeller, then check the intake holes to make sure they are not plugged and there is a chance that the discharge tube is plugged too.
