NO WATER COMING OUT THE PISSER
HILTON
I BOUGHT A USED BOAT AND I HAVE A MERCURY XR6-150 MOTOR. WHEN IDLEING THERE IS NO WATER COMING OUT OF THE PISSER. IS THIS HOW IT IS SUPPOSE TO BE. I JUST CHANGED THE WATER PUMP AND STILL VERY LITTLE WATER COMING OUT. . <br />THANKS
Boatist
Re: NO WATER COMING OUT THE PISSER
Most motor did not use a PEE hole until around 1980. I did not see a year but if it is older than 1980 may be ok. Does it over heat???
tufftango
It maybe hard to believe but small insects have been know to build nest in the rubber line that runs to the pisser. Remove the line and small cap and run a small wire through it. Also if you had a badly worn impeller, small pieces of rubber could have clogged the line. It doesn't take much to cause a blockage.<br />Good luck...
stratos1
Remove pisser tube from outer engine cover. Try<br />blowing through this tube by mouth. Start engine<br />w/ running water, warm to operating temp. Cut motor off, blow through tube and repeat several<br />times. Maybe you could clear a blockage. If not <br />successful, may be worth traceing water passages<br />to find blockage before engine seizes.
