No voltage in Bayliner
wardvette
Hi all, I have a 1998 Bayliner Capri 1750 w/ Mercruiser 3.0. The slave solenoid was going bad last weekend so I jumped it with pliers a few times to get us around the lake and then bought a new one on Monday. I tried putting it on last night but couldn't get to the nuts behind the solenoid so I gave up. This evening, I went back and took off the bracket the solenoid was mounted to so I could hold the nuts with a wrench. After putting everything back together, it won't start and none of the elecrical components work. The stereo and blower motor are wired to come on even without the key but they still have no power now. I tested the hot lead going to the slave solenoid and do not have power. I used the flame arrestor clamp as the ground since I know it is grounded (verified with meter). The battery is showing 13 volts and all fuses are good. Any idea what this could be?
Thanks!
maxxman04
Re: No voltage in Bayliner
wires hooked up wrong on solenoid, no ground on motor, no power cable hooked up, circuit breaker tripped (should be one on or near motor, usually 30-50 amp) push to reset.
thannah84
Did you mount the bracket back to the engine block? If not, that's your problem, that is a ground. If you did, sounds like you don't have a ground or the 50 amp fuse back there blew...
dubs283
yep, you got a wire missing somehwere, head up to the adults only sticky and check out the troubleshooting guide for engine starting problems, there is some great info and pix too!!
