No trailer switch?
fasteddie760
Hello all. I recently bought a 1990 Eliminator 234 Edge and replaced the trim sensors to fix a trim gauge problem I was having. After replacing both trim sensors and trying to adjust the trim limit, I noticed this boat does not have a trailer switch. And rotating the trim limit sensor does nothing to the length of the rams.
When I set the trim gauge to read correct in the down position it only shows 3/4 when fully up. What is the ram length when fully rasied on a bravo one drive? Mine is 27" center-to-center.
I attached a picture of the only trim switch in the boat.
that is a tilt and trim switch.
I bet either you push it further up (second detent), or you push down and up
