No top end!
barkeater59
I have a 1971 Johnson 6 horse. It has a lot of hours on it and the water pump has been replaced a few times by my father who bought it new. It starts easily even after sitting for a few years. Idles very smoothly and runs well at troll or full throttle. The problem is it doesn't have the thrust it used to. Maybe half as much. Knowing that it has lost the water pump before I wonder if it is just tired and needs to be freshened up or maybe the carb needs cleaning. What should I hope for with regards to pressure when doing a compression test? Is my issue symptomatic of another problem? I don't want to spend my whole weekend at the lake tinkering and if I bring it home to work on I don't have water nearby to test it. Any advice would be greatly appreciated.
boobie
Stop at a BRP dlr, get some Engine Tuner in a can, take it to the lake with you and do a good decarb on the motor following the instructions on the can to the letter. If it helps, do it again.
flyingscott
Have you ever replaced the points and condensers if not do a cylinder drop test.
OptsyEagle
When you lose most of your power at the top end it is usually a sign that you are only firing on one cylinder. As flyingscott said, do a cylinder drop test to confirm.
Fire up the motor and let it warm up. Bring it to a fast idle and with a pair of insulated pliers, pull one spark plug boot at a time. The motor should be able to run on only one cylinder, albeit with dramatically less top end power, so when you pull a plug boot, if the motor dies you then know that the other cylinder was never firing or was very weak.
Honorary Supreme Mariner
If the coils are still original they will be cracked and long overdue for replacement.------Likely the motor is running on one cylinder !
