Re: no thermostat
A lot of people think removing the thermostat will help the water flow better when the motor is actually starving for water from a weak pump. If that's the case, you need to rebuild the water pump.<br /><br />Motors run best when they can maintain a fairly constant temperature. If you run a motor cold that is accustomed to running warm, you can do damage.
