no start 60hp suzuki 2012
I have a 60hp Suzuki 2012 motor that want start anymore. when you turn the key to the run position you hear the beep then turn it to the start position and nothing happens. I replaced the ignition switch thinking that would do it but it did not fix it. I checked the neutral safety switch and it was fine. I checked kill switch and that was still working fine. I checked for voltage at the starter wire when the key is turned but got nothing.
I did jump the starter wire to the batt + post on the starter to make sure the starter worked fine and it turned over. I checked the starter relay and switched it with the main relay to test it and still no starting.
does anyone have anything that I might have forgotten to check
I was turned to the ECM next but those are crazy expensive.
it might be covered under warranty but I would love to be able to figurre this thing out soon, thanks for the help!!
