Grant Brown
- Mar 13, 2004
- 390
History: Purchased just before Christmas last year. I bought it the day a major winter storm hit our area. It wasn't winterized at the time I bought it. It ran good the day I got it. I ran it around the bay a bit, brought it home and drained the block and manifolds in the snow storm at 10:00 pm. I never got to winterize the fuel system.
I got it started yesterday (hard starting and had to prime the carb) and warmed it up. After it ran a bit rough for a minute or two then it idled down nicely and held steady at about 750 rpm. I changed the oil and then today when I went to fire it, the motor turns over, coughs, sputters almost goes, but won't really catch. It will start to go if I give it lots of throttle (in neutral) but it seems to want to completely rev up and even then won't stay running. As soon as I let off the starter, it dies. While all this is going on it seems to be blowing some black smoke.
The whole time it was doing this, I did not hear the fuel pump working. Could this be the problem? I pulled the harness off it and used a test light but got no power. How do you test the pump?
This 1993 Spectrum has seen some salt water - I have already replaced the starter and all the electrical components on the trim pump.
I was hoping to get out for a good run this weekend - not if I can't figure this out...
Thanks for any ideas,
Grant
Grant
