Re: No sparks on 115hp
Thanks for that. I got this motor partly dismantled. Obviously, it had had a problem and someone had been pulling it apart to find it. Well. I pulled a bit further and found a totally knackered water pump so my guess is that was the cause of whatever grief he was having. Anyway, it is mostly back together and has no spark. I spent hours going thru the wiring then found that the fuse had blown - doh. But to no avail. Then, I sussed the safety switch behind the throttle lever - got to get that position correct for power. Took the flywheel off and checked the sensor gap - OK. Can't really see much else in there. Checked the external coil and it has 12v going in - blue wire but nothing coming out - but resistance wise it seems OK. It is my main suspect at present, and cheaper to try than a powerpack. What do you think?
PS Mechanically, two pistons have been oversized so it has been apart before and worked on. Better still, there is almost no corrosion at all either inside the water pathways, or externally. Not bad for 1970 - doubt a Japper would last as long.
