After a few test I was able to determine that numbers 1 and 3 were not firing. So I tested the coils on all seems to be working after swapping wires around. What seems to be the problem is the c-d units. What is weird is that both c-d unit (Which are blue) have what I would call two channels on each unit. But one of the channels on both c-d units are not sending power to the coils. So my question is "Can both CD units have one channel bad on both? What are the odds. That is too weird for both to be bad. But I see in the book that there is a trigger, does this supply power to the c-d units? Or does the the stator supply power to the cd units. What I will do tonight is check the juice coming from the stator. There are four lines, so I am assuming that each lines are for each cylinder. <br /><br />So if I test stator and only 2 of the 4 lines are getting juice then I would say that the stator is bad.<br /><br />Any ideas would be great. Because I wouldn't want to buy some c-d units (Which are over 200 bucks a piece, which I may need two)when I don't really need them.<br /><br />P.S. I also can't find the serial number for my motor. That is giving me hard times, since I need that to figure out what parts I need to order.
