Dear Forum, Every once in a while I have to go through this ritual to start my 90hp Mercury outboard, 3 cyl. The serial number is: 0B302485. The engine turns over beautifully but has no spark to any of the cylinders. For whatever reason, at times it has spark and will start and run fine all day. Then after sitting for a day or two or a week or two I am unable to start the engine because NO SPARK. Im lost, obviously! I checked the stator and the red and blue wires ohm as if there is an open between these two wires. The ohms between the red wire and ground ohm out correctly. I disconnected the black/yellow kill switch wire from the switchbox and still no spark. Any direction with this motor would be great and if anyone has further checks I can do I'd appreciate it!
Thanks
Thanks
