no spark....
stevek54
i have 1987 50hp force out board. the motor sat 4 2 years. this year its started ok and run great the then first 3 times . but hte last time it started ran 4 20 seconds than quite and wouldn't start again. after checking the motor i found it doesn't have spark . any sugestons. i need help. thanks steve k.
jerryjerry05
Re: no spark....
Does it have a kill switch? The flywheel key could have sheared.The powerpack or trigger or stator could be bad.
There is a lot of things to look at.
Make sure there is no spark.If there is spark the fuel system needs help. Then get a manual and start troubleshooting.J
