no spark
koma80
hello everyone I know you guys will need more info buy just throwing this out there for a friend.It`s a 1998 crestliner 2660 454 (carburated) with a bravo outdrive.His problem is no spark coming out of the distributor.Checked the coil,hot on both sides w/key on,cranking still shows hot on both sides with out pulsing the test light.The rotor has a reluctor wheel made on the bottom that passes through a pick up magnet that has 2 leads that goes to a remote module.It looks to be some kind of hall effect set up.Where would be a good starting point to diag??Thanks for any and all feed back
