Re: No spark to my 45hp chrysler
There has to be some better experienced Help Coming Soon!! Meanwhile:
1. Other than the cracks in the coil, what other recent history do you have on the engine?
Was it running fair or fine before now?
2. Have you checked for 12 V power going to your coils with the switch in the on position?
3. Have you checked the appearance conditions and proper gap of your points and magneto appearance?
No burned/pitted points, a .20 gap (I think, at the highest point or TDC,Help!), clean stable magneto?
This means pulling the flywheel, I could be getting too for ahead before better help arrives. Help!!
I have a 35HP Chrysler 71 or 73 (w/o alternater) and I find it reasonable to troubleshoot if you have basic small combustion engine knowledge and experience.
If the points are bad, is there an electronic ignition kit (reasonable in cost) that will serve you better than the points? That is saying a lot, because I have replaced my points once in 25 years on my engine.
Good Luck,
Joe
