No spark on one cylinder?
KeithV
I have a three cylinder 50hp Merc. (1986-90) with no spark on one cylinder, was told it may be the 'switch box", any other thoughts/ideas before I spend hundreds on that part? Cheers!
achris
More fish than mountain goat
Re: No spark on one cylinder?
More likely a coil or trigger. You have 3 coils on that engine, swap the dead one with a good one... See what happens.
Chris......
chum1
here is a couple shots of what i just found out on mine, I think it has a similer ignition system but 4 cyl.
1st pic:a weak or no sparky on one plug
2nd pic:swapped wires on these two coils and the problem changed to a different cyl. (spark plug) thus the coil was good.
3rd pic: found a loose connection on terminal end, you can see where it has been arcing. tightened that terminal and the spark returned to the plug:)
Good luck
