I have a 25E74M Johnson that is eating my lunch!!!!!!!!!! I have changed points, condenser, plug wires, plugs and still I have no spark on my tester on the bottom cylinder. I have changed coil positions, unhooked the kill wires, set and reset the points at .020 and nothing. I got it going this morning and took it to the lake and ran about 15minutes and then stopped firing. I can get it to fire very little with a plug but nothing thru the tester at its closest setting. Everything on the upper cylinder is fine. I just tried synchronizing the points with my ohmeter with one point set at about .025 and the other set at .016 to get them 180 apart between the marks and still nothing. I need help. Thanks.
