capsnumber1
- Mar 25, 2006
- 45
Hey everyone, I have a 1989 Evinrude 120 HP 2 stroke VRO. It has not been running well at idle so I had some tests run on it. Mechanic told me the bottom 2 cylinders had no spark. We replaced the powerpack and that did nothing. He says there is good compression in all cylinders and the problem is electrical. He says the only way to narrow it down is to start to replace other parts - which as you know can get quite expensive. Anyone have any idea what could be causing this? Thanks in advance!!
