i have a crownline 97 mercruiser 5.7l carb and after storage for 2 years it started right up, after 5 mins it shutdown and never started up ( NO SPARK) i changed the coil and the dist sensor per the troubleshooting chart that i have seen in the forums. however when the chart states to check wht/ red terminal for voltage it does not explain if the ignition has to be on or off. when the ignition is off i get 0 volts and is on I get 11V. can someone clarify this to me? thanks
