No spark on 95hp merc where do I start?
molsenice
Have a '67 merc that has always been great but must admitt, did a dumb thing, by mistake, I crossed the battery cables (battery was backwards). There was a small spark, so I did not connect, then I noticed my mistake. There is no spark at the plugs when they are in the motor, the plugs do spark however, I put them in my Harley and they lit up like a thunderstorm (had them laid against the block. I suspect I cooked somthing but do not know where to start.
tommays
Re: No spark on 95hp merc where do I start?
you need to do a little better on the what it is ? <br /><br />tommays
molsenice
I suspect the coil is bad I tested and found not spark with a test meter that reads the curent pasing through the wire. Again, this method showed a spark on my bike but none on the boat am currently pulling the coil and will replace
molsenice
the motor is a 95hp '67merc
tommays
60 RENAULT 68 I/L4 1965-1968<br /><br />is it this motor<br /><br /><br />tommays
molsenice
No the motor is a 95hp 1967 Mercury
molsenice
I have the coil out there is a number "332-2826" which I assume is a part # however the folks @oldmercs.com do not recognize the number. I am going to see if a local auto parts store can test the coil.
tommays
so then its and outboard ?<br /><br />tommays
molsenice
Yes it is an outboard, sorry. Clue me in on why your replys do not come up unless I log out then on then search for my name?? What I have done since your last reply: Coil is out of the motor, Part # is 332-2826 serial #2124524(on motor). Have brought coil to a marine parts store and two other marinas, 1 that deals with merc's and Boston Whalers (which is what I have), Chic's Marina, Lake George NY. Was told that the touching of the battery terminals backwards definatly cooked the coil and posibly other damage but that was doubtful. No luck on replacing the coil, it is nolonger available from the manufacturer. Was encouraged to try finding one online, but where to begin? most searches end up with a lot of usless stuff. My e-mail is fdougherty@gfsd.org, unless your posts start to show up, hey - thanks
cosander
you may have more luck in the outboard forum
tommays
you need to move to the outboard forum this is for sterndrives <br /><br /><br />tommays
cosander
there are a few threads about your motor good luck
M
Mod3
Guest
Moving to Mercury Outboards.
