I'm beginning to trouble shoot a no spark condition and the first thing I run into is a question about the starting RPM. I have no rev counter and the tach is not working so is there some way that I can I use the frequency position on my DVOM to measure the engine RPM? I am fairly familiar with the DVOM but have never used the frequency counter and my book does not say much about the use of it.
Also, where is the trigger circuit. I think the stator coils supply pulses over wires marked sensor (1-4) to charge capacitors (1-4) in the power pack that correspond to cylinders (1-4). How do the capacitors know when to discharge into the coil (1-4) and fire the plug (1-4).
Also, what is the firing order?
I don't have a book yet. I'm getting my info from some stuff that I downloaded from CDI. Which book is best? I've not seen a factory service manual. I have seen Selco, Clymer and Cook but don't know which are best. Cook seems pricey at $70. Don't know if it is that much better. I would prefer a factory book if they can be found.
