24gradyexp
- Aug 18, 2004
- 25
Engine 1999 250 EFI s/n 0G899xxx.<br />Switched coils (not just the wires) with cyl # 4 to prove coil was good\bad and coil from #6 fired on #4, coil from 4 did not fire on 6. Stator or ECM? I put a meter on wires from stator and get readings 1.1k on most coils except for the one to six, that reads open. I spun flywheel over to make sure magnet would have no affect and the coil still reads open. Are there any other tests I can do on the Stator to prove it is bad before I pull the flywheel off and replace it?<br /><br />Thanks
