kumoparris
- Sep 6, 2018
- 14
I have a 1994Spectrum with a 70hp Force outboard. I am assuming that the Force is a 1994 as well. I am having trouble getting the engine to start. I was running it one day and then stopped and it wouldn't start up again. After getting it home, I checked for spark on all three spark plug wires with a spark plug tester and didn't get spark on any of them. I found a discussion on here about things to check regarding the stator and the rectifier and tried to follow it but my wiring situation is different. Coming from my stator I have a blue, red, 2 yellow and a black wire. I disconnected the two yellow wires to test the rectifier (no spark). From there I am not sure what to check because the other thread mentioned checking the red and red/white wires together and the blue and blue/white wires together. Since I don't have the corresponding red/white or blue/white, how do I complete the stator testing? Also, I read that you can test the stop circuit by disconnecting the black/yellow stop wires. Where are these? I found a black/yellow wire near the stator wires and assumed that was it.
