No Spark, Johnson / Suzuki DF70
Floatinghat
Trying to figure this out. Boat is at the mech ( good guy) it wasn't running when I brought it in believe due to fuel pump. bad cmp sensor, which tests good. Replaced VST and there is no spark. He says only code is a 2-4 which indicates cmp sensor, which tests good. And the manual says that would put in limp mode and should start? anyway he believes the ECM is bad because there is no spark. There is power to the coils etc. However, he plugged in a new ECM from a DF70 and the issue didn't resolve. I guess my questions, is there some way or place I can have ECM tested and repaired if needed? Should the ECU from a df70 work?
