Re: No Spark at 2 Plugs
Ignore the part where I asked about the black wires. I found out that the stud they were mounted to wasn't grounded (even though all the other identical studs were...weird), so I moved them to a different spot.
I checked the resistance between the two stator output leads and it was within spec. I also checked and there was no continuity from either wire to ground. I also checked the resistance of all three coils and it was within spec (again, I'm fairly sure these are good since I put them all on cylinder #2 and they worked).
Now I need more details on checking resistance from where to where from pnwboat's post and more suggestions on what else to test. I still haven't swapped the two CDI modules to see what happens.
Thanks!
