idaho alan
- Jul 4, 2009
- 3
1st time here, sorry if this is too long...
I have a 1973 85 HP Chrysler outboard (model # 857HE, Ser # 8377). This motor has performed flawlessly until now. First the starter quit, I replaced that, now I don?t have any spark! I have probed through the wiring and found the following:
Key off: At terminal block; Red hot, Blue cold, White cold. All this seems as it should be.
Key on (run position): At terminal block; Red hot (12.4 V), Blue hot (12.3 V), White cold
At CD Unit, Coil and Dist:
Red hot (CD power in)
Blue hot (CD Ignition in)
Gray (coil +) cold 0.0 V
Black (coil -) cold, 0.0 V
White/Black (Dist +) 12.3 V with multimeter and buzzes with probe (typical ground one side, light bulb, hot other side which is a sharp point). I suspect the buzzing noise is adequate voltage with very low amperage (current) inadequate to light the light.
Key on, start position, starter cranking, Coil + (gray wire) still no light with electric probe. I believe I should have voltage going to the coil.
When I turn the key off, the Distributor wire (white/black) shows about 1.3 V and is dropping steadily (by hundredths of a volt). The Ignition terminal (blue wire) at the terminal block also shows dropping voltage (less than 1 V, dropping steadily). This could be a condenser draining?
Any suggestions?
I believe I have points ignition since I don?t have any other wires going to the distributor (ie: no blue wire). CD unit is all black, info on back is Motorola model # 6CB2012B, Ser # 88933 and a sticker with 185002.
Help, pleeease. Daughter standing here with the tow rope in her hand...
Any suggestions?
