no spark 125hp 88 force
holmzee
ok I just relpaced the stater and trigger and still have no spark the fly wheels turns good the starter engages good and no spark I unhooked the blk and yellow kill switch wire and then when I turned the key nothing so that seems to be working what else do yyou guys suggest thanks oh and where can I get a rebuild kit or used tilt trim motor
CoachHolland
Re: no spark 125hp 88 force
You can get a used tilt and trim off ebay. There's a few on there right now.<br /><br /> http://search.ebay.com/force-tilt_W0QQsokeywordredirectZ1QQfromZR8 <br /><br />As far as the no spark condition, are you getting no spark on all cylinders or is it just a couple?<br /><br />Could be wiring, could be power packs, could be coils. Need a bit more info to give a guess as to the specifics.
