Re: no reverse....
Hey 76....When was the last time you checked the gear lube? Reason I'm asking is that the shift mechanism is a pump in the front end of the gear case. Shifting redirects the gear lube to one side or the other of a small piston that slides back and forth to shift gears. It's a simple effective system but clean lube is a must. Its' possible that the piston is stuck and won't go to the reverse possition. <br /><br />It's not a difficult job to check the pump but requires the removal of the lower unit and disassembly of the gear case. A good service manual would show you how it's done.
